some of the stock appearing dual-ports have essentially no rod-side seal, so I don't thing they would work at all (i.e. stay away from ebay , been there, done that )
the leaks can affect the boost control if they are large enough.
the issue with using manifold pressure on the balance side usually only becomes a problem with the high-boost + high-backpressure guys that need lots of pressure to hold the gate shut.
for "street" guys it will likely work fine.
Bob
