Coelacanth
- Jul 7, 2014
Usually they're placed in front of the rad, so directly in the airflow...thus it should be at least as efficient as (or better than) the built-in unit, I would guess. As long as the fittings/hoses were the same diameter as stock.
What are the dimensions of the 2 coolers? Surface area plays a part in cooling effectiveness...it looks like you and I will be doing a similar rad upgrade in the near future.Looking at this cooler on the Summit site and it specifically says it is a transmission oil cooler; doesn't say engine oil. Given all that has been said about one vs the other, restrictions, etc. I'm wondering if this is a good one for engine oil. The inlet/outlet size is the same (1/2" NPT) as the B&M "Engine Oil" cooler listed on the gnttype write up.
