20psiofevil
- Feb 10, 2013
I know some of you guys use the red's piece with the 2nd pump wired on a boost switch. My question is, is there a one way valve after that pump so the main pump just don't pump through the 2nd while at cruise and idle.
I'm upgrading my fuel lines to -8 feed and return (ordered $320 worth of fuel lines and fittings last night) so wonder if I should just run both pumps all the time and skip the boost activation switch.
