Seeing as Cutlass and Regal doors are identical, that is your most logical choice. The other G bodies require you swap the gasket between the mirror and the sheetmetal.
2nd gen camaro/firebird will work (bullet shaped piece only) the base is different, u just use your base (pedestal) with the f-body mirror housing, it will work.
