Door locks 87 gn
87gn1
Hello everyone e looking for a little help on my 87 gn. My door locks have never worked since I bought the car time to fix that so I checked the breaker in the fuse box has power relay in passenger side kick panel shows its getting power when I hit the unlock button on either door nothing happens. I replaced the relay part number 20306055 still nothing took passenger door apart I get power to the switch which I believe is the orange wire should the relay be maki g some noise seems all the wiring is hooked up cant find anything undone. I realize it could be power door lock motors I guess but in both doors any help or advice is appreciated. Where do I buy new door lock motors at. Thanks again
Your switch might be bad. Mine works if I press it harder. Neither door switch works? Sound like you are getting power and I doubt both motors are bad. If you take the door panel off you should be able to run power direct to the motor or else jump the switch and that should energize the lock motors.
