On my drivers side door this plastic piece is broken and the window is loose when all the way up. Can i replace it without replacing the entire glass and what is it called? Thanks in advance.
I'm not sure of the technical term.. It's a stop, guide lock when the window is in the up position. I believe ther riveted on, so, you should be able to replace it. if you can find one, maybe used?? Hope this helps. Phil.
The part is included in Kirban's Anti-Rattle kit. You can take it to a glass shop and let them rivet it on for you. (Takes like a 1/4" - 5/16" rivet for use with the Brute rivet gun)
I replaced mine last week. I got a buddy in the auto glass business. It wasn't bad for him to do, but if you've never tackled anything like this before, let a pro do it. All it takes is one slip of the drill and you got to replace your window. I'd take it to a glass shop, they wouldn't charge very much to drill the rivets out and rivet the new piece in and they could adjust your window so it fits right because when I tried it, it was a PITA... Just my opinion
The kit I got from kirban that piece is now black and they ship with screws. I wasn't comfortable with that method of fastening and riveted it. I've got a post where I cross reference the makers rivet numbers fyi.
I replaced the drivers side window stop/guide (thanks Brian!) yesterday and it was cake. Since the window was out of the door i figured it would be easier to do the lift motor so i did and it was.
For the stop/guide I used a angle grinder to grind down the rivets and then drilled through the rivets. It seemed easier this way. I then used bolts, lock washers, and nuts to re-attach.
