Mine is an Innovative as well, GT70.
It has the 3/8" NPT pipe tap fittings on each side of the housing, oil fittings top and bottom.
Here's some pics. of what I did.
Used a stock off the shelf NAPA hose with molded right angle for the front fitting, and stock heater hose for the back, one is 3/4" for the drain, other is 5/8" for the feed.
Spectra sells the 1/2" NPT chrome water/oil/gas fittings in the ricer section at Pep Boys, dress up parts, I used standard brass adapters such as close 3/8" Nipple into the turbo, then a 3/8" NPT to 1/2" NPT adapter females to get to 1/2" NPT to screw the spectra hose barb, 5/8" hose, chrome fitting into. Other end had to be larger for the drain and right angle
Relocated the aftermarket water control valve a bit and used T's to feed and drain it.
Others use the stock throttle body smaller water lines for the feed and drain.
It's easy to do once you plan it out with off the shelf stuff.
