Recently I had my motor hooked-up to a computer monitor for a diagnostic check-up. How are the reading??? My car is bone stock including chip. This is what was on the print out...............
--- BASIC INFORMATION BLOCK---
Coolant temp 192 F
Mass air Flow 005 G/S
O2 Cross Counts 013
O2 Volts 0.480 V
RPM 0925
Throt Pos sensor 0.42 V
--- ENGINE INFORMATION BLOCK---
Air Flow 005 G/S
Backup fuel OFF
Block Learn Mult 150
Clear Flood OFF
EGR D/C (%) 000%
Idle Air Control 020
Intergrator 138
Knock Signal No
Loop status CLOSE
LV8 (Filterd Load) 032
Manifold air Temp 102 F
O2 Fuel state LEAN
Spark Advance Progrm 34 DEG
Kinda wondering about that Throttle position reading.............
Coolant temp 192 F
O2 Cross Counts 013
O2 Volts 0.480 V
RPM 0925
Air Flow 005 G/S
Backup fuel OFF
Clear Flood OFF
EGR D/C (%) 000%
Intergrator 138
Knock Signal No
Loop status CLOSE
O2 Fuel state LEAN
