Ok, for some reason, my engine seemed to have developed a slight miss, in which I can notice it at idle and can feel/hear puttt putt puttering through the exhaust while cruising. The car seems to boost fine.
I was thinking its either a spark plug wire, coil pack, or spark plug. Or maybe an injector?? Or bad gas?
The wires seem to be in good shape, and all the coil pack terminals are nice and clean. I want to run the motor and disconnect each wire one by one to see exactly which wire/cylinder has the miss.
Is it ok to disconect the spark plug wires from the coil pack ends while the motor is running? Or should I only disconnect them by the boots on the spark plugs?
