Jerryl
Tall Unvaccinated Chinese Guy
- Dec 14, 2004
Yes, was aware of the benefits of reduced piston speed. Curious how much destroke and RPM others are saying is the ticket. I'm assuming Jerry started this thread based on another recent thread where destroking was said to be the way to go. Like Jerry I'm looking for potential benefits beyond what conventional thinking tells us.
To realize the benefits.. you need to
Think beyond just the engine.. thats only part of puzzle.. the destroked engine is just the enabler
Yup. Tuning intake to tailpipe. Throw one of these rotary mufflers in the mix and it gets really complicated really fast.
Cabin fever discussion.
Let's say you have engine combo X.
You destroke, maintain CR, same cam/rpm/heads/valves/boost/fuel. You adjust the tune . . . .
What's your opinion or experience on the performance results?
You won't get the right result because you can't properly optimize the combo with the same targets as the old combo.everything that changes should be for the target goal this is critical.stroking and destroking needs totally 2 different approaches to the build and tune and converter and gearing otherwise it's just trying to fight with one arm tied behind your back.Cabin fever discussion.
Yes of courseHere's my take on thing's.......The OP Jerry knew already that a short stoke alone wouldn't make more power. He was intrigued by comments regarding destroking in another thread and created this one as a platform for further discussion. You know it's a good topic when the fast guys start to respond
Yes of course
His choice of words said it all.
He could care less what you say this was nothing more than entertainment for him
Yup thats one way to go fast210 cu. in. Buick V-6 with two 67mm turbos developed 1375 HP at over 9000 RPM on Kenny's dyno!
Exactlywould say nobody that is destroking would be leaving the same cam/rpm/heads/valves/boost/fuel ... nobody is just gonna destroke and adjust the tune .. that be silly
Posts 11 and 13 gave this same answer.Seems like most of the time people never really answers the question.
The answer to the OP question is simply
Less power
