6 6SENSE Member Joined Jun 3, 2001 Mar 9, 2004 #1 I never heard this before, or did it before, but I recently read in two books that you are suposed to depress the spring-loaded plunger on the front of the proportioning valve while bleeding. Is this true? Is it necessary?
R Red Regal T Senior Member Joined May 24, 2001 Mar 9, 2004 #2 I have vacuum brakes and I didn't depress the plunger to bleed the system.
salvageV6 Daily Driver Joined May 25, 2001 Mar 10, 2004 #3 Yes you are supposed to push the plunger for bleeding. I believe all it does is cut down on the time necessary to bleed. I have bled them successfully both ways.
