incubus2432
Douchebag
- Jun 23, 2006
So I finally upgraded to the TurboTweak 6.1 wideband chip and went for a few quick test runs. The "WB-108" file is with the chip set to correct to 10.8 AFR and the "WB-110" is set to 11.0 AFR. The only issue I saw was that my TPS needs adjusted but other than that I was pretty pleased with the run at 10.8 AFR.
On both "tests" I got some knock at gear changes (on the 11.0 file you can see a 7+KR which I, obviously, don't like but it was at a gear change so it may be false). For the sake of safety I went back to the 10.8 AFR setting but wanted to make sure I'm not missing something.
To view the files my wideband is set to "PLX" and Analog 4 is set to "pressure 100psi". (fuel pressure).
Thanks!
Thanks!
