Okay, my alternator just went on the fritz, while I had loaned my car to someone. Fortunately they recorded a few runs.
The thing I don't understand is that even though I had very little voltage correction, I had tons of black smoke out the tailpipe, horrible idle, and lots of O2 correction (13% - 15%) at WOT.
After I replaced the alternator, all returned to normal.
What is the impact of a low voltage (11.8 - 12.2 volts)? The fuel pressure doesn't drop, so is it correcting for a phenonmenon that I am not aware of? I guess the injectors would open a bit slower, but what else happens? Does the reading from the oxygen sensor become incorrect (causing extra enrichment and therefore the black smoke)? Injector DC was a bit higher than normal, even though the O2 sensor was trying to make the engine richer...
Does the injector opening speed (and therefore batt corr%)matter whether it has high vs. low impedance injectors?
-Bob Cunningham
bobc@gnttype.org
-Bob Cunningham
bobc@gnttype.org
