Ever noticed these cars run much nicer, more horsepower, and less lag on a cool dry morning. After the car has sat on hot pavement at work all day and as soon as I start it it's not the same high energy car I drove into work with. It even makes a gurgling sound during any acceleration, soft or hard, but usually only in the afternoon.
Now I know air density and moisture may play a part, but what about temperature of the fuel tank?
Cooling the fuel does work, but ………. A good pump with the right voltage and filters puts out around 280lph.
At idle, +95% is returned to the tank.
So the “heat soaked fuel under the hood” (which is a small % of the total available volume with a full tank of gas) is returned to the tank very quickly.
The fuel in the tank is at around ambient temp.
Lowering temp of the fuel from ambient at WOT, takes quite a bit, because of the volume going through. Even with an “ice can” I bet you can only lower the temp about 10F (I pulled that number from you know where
Your observation of a HA motor being very heat sensitive is very true, but I am not sure if “cooling the fuel” will result in noticeable performance increase. The IC’d cars have very similar fuel temp issues, but they seem to run stronger overall on hot heat soaked days.
If you ever have a chance, log the MAT on a HA vs. an IC’d car.
You will be amazed.
Your observation of comparison is “cool dry days”.
There is no solution for that other than “cool dry days”.
The "gurgling sound" may be a function of the fuel map, i.e. running rich.
What chip/set-up are you running? What does the WB say when it "gurgles"?
