turbot-ttop
- Aug 12, 2014
My list of mods is in sig ecm is modded goint to use 120# need help with the pump going double pumper need advice on wich one.thanks
I know it is I'm planning on bigger turbo and converter
Make sure you double check the voltage at the pump !! Booster just extends how far you can push the Pump.. DW pumps work very well at higher voltagesMy pump is all allready hotwired do i still need volt booster?
