Computer won't stay running. Starts up ok they about 10 min later shuts down and won't restart. Unless you turn power off in the tower. Does this even if your in the Bois. Will Start after sitting for a few minutes. Will running everything in device manager is ok, posts ok,cpu mb not overheating, cpu speed is ok. Running XP, AMD2100 cpu and A7V600 Asus motherboard. No kind of errors show up when it shuts down.
Once it stayed running for awhile, shut it down normal way. Pushed the power button later, nothing. Had to turn the power off at the tower then on again and it would start. Run about 10 min shuts down like someone pulled the plug.
JFH
JFH
