this engine dynoed 570 to the wheels before a wrist pin damaged #5 cylynder this deal includes
complete engine with ported iron heads
ported intake to match
ported throttle body
206,206 billet cam double roller timing chain better lifters the good ones zero lash
posten headers and down pipe
72lb injectors
modded ecu with mer setup works perfect
scanmaster latest version
your getting everything it takes to make it run im going to ls motor.
The cylinder will need to be sleeved but everything else looks good this motor only has 1200miles on it also has billet mains.
For serious buyers i also have a 9/11 converter and 200r trans that needs a rebuild converter works great.
complete package motor with all accessories and converter,trans and anything else you might need $4000
converter and trans alone $1000 if i sell engine
motor with everything but converter and trans $3000
will not seperate parts only the packages ive priced thanks
precision 6152 turbo with engine for an extra 400
if your serious make offers i might just take it.
72lb injectors
