I dunno, that's not what I would call complete. But that's just my interpretation. You would still need lots of parts that won't work off your hot air. It's doable, but bring some cash. Off the top of my head I see a need for headers, turbo (yours might work) and oil drain tube, wastegate, upper plenum and throttle body, fuel rail and injectors, coil pack, harness, vacuum block and associated tubing, and starter (again, yous might work). If I broke a crank or something went wrong with the long block, that engine would be exactly what I would be looking for. I bought one for my hybrid build that truly was complete from the radiator to the trans output shaft, harness, ecm, even the fuel lines and sender for $2500. I understand you already have the trans, but I'm guessing the rest would add up rather quickly.
