Theese lifters are used and have 600 miles on them, I switched down to a more streetable lifter due to the fact that my car is 99% street driven, Theese are recommended for use in high RPM buildups. I am taking offers,Thanks
Chevy 4.3L V6 Retro HYD RLR Pro Magnum Lifters
PART #885-12
$459.00
DESCRIPTION:
Pro Magnum Hydraulic Roller Lifters
Chevrolet 4.3 L V6. For use in blocks originally equipped with hydraulic roller cam ('87 to present)
COMP Cams® Pro Magnum Hydraulic Roller Lifters™ are specifically designed to perform at higher engine speeds. When engines are equipped with a hydraulic camshaft, high rpm is limited by the improper position of the internal piston as the lifter inevitably "pumps up". This improper location results in open valves and therefore leads to lost power or sometimes even engine failure.
PART #885-12
$459.00
DESCRIPTION:
