calais1965
- Mar 10, 2009
Hello!
I have been building my car for strip, i have ordered tons of parts and few are missing...
Body have been modified with lot of weight savings fiberglass bumpers, hood lid, aluminium drums, ac and door safety bars removed etc.
I have hotchkiss tubular arms in front and ssm control arms rear with airbags.
Fuel system is Jaz tank, 1/2" feed lines with aeromotive a1000 pump+controller.
Transmission is extreme automatics stage2+transbrake, converter vigilante 3200 lockup.
Motor is:
109 block
+30 Je Pistons
h-beam rods
steel crank
GN1 aluminium heads
70 tb
Kb-headers
alky
pt-70
3" down pipe
Big front mount cooler
billet caps & girdle
New bearings & oil pump
roll master Timing set
Tial wastegate.
sfi harmonic balancer.
Maf translator pro
Modded ecm
I think i will use 120 lbs injectors and buy spohn roll gage...
Question is:
Should i go with E85?`
What would be best cam for this setup?
How fast and how much hp this combo will work???
Thanks!
JP
Motor is:
109 block
+30 Je Pistons
h-beam rods
steel crank
GN1 aluminium heads
70 tb
Kb-headers
alky
pt-70
3" down pipe
Tial wastegate.
Maf translator pro
Modded ecm
Question is:
Thanks!
JP
