dwall
- May 25, 2001
I have a column shift in the project Regal. It came from a 4 speed automatic "base" Turbo Regal rust heap. The column was installed in the project during assembly. Someone (nameless for now) forgot the shift lever return spring was not in the column at the time. Needless to say the shifter does not work as it should. I need a replacement spring. Will one from a 3 speed column work?
Anybody run into this before? Any ideas? I have a parts car with a NA V6 that can furnish the spring. Maybe the best answer is find a replacement column? Or maybe not? I checked the Junkyard Donor list but didn't see any info on swapping columns from other G-Bodies. Maybe some 4 speed columns out there?
Any help?
Any help?
