Classic FAST Bank-to-Bank Questions
peterkin
..it isn't rocket science
So, I just got an older system in the mail from threerail. It's a classic B2B FAST system and I have a couple of questions about connecting this thing.
Now, I understand that the wide band 02 had to be extended and the previous owner pulled the pins out of the FAST side of the 02 sensor connector. I was wondering if someone could tell me where the blue and gray wires go on that harness? Does the gray or the blue wire go on the end of the connector? Although these two wires (gray and blue) look like they aren't connected to anything on the 02 sensor side of the connector, I'm sure there is something inside that connector (i.e. resistor) that these two wires need to connect through.
Second question is about the MAP sensor. There is a splice in the middle wire of the MAP sensor and I'm not sure where it goes. The two connectors that split off from the MAP connector itself, where do they plug in?
What I really need is a manual or a wiring diagram. Any help would be greatly appreciated.
