Rodimus_Prime
Dirty Bird
- Apr 30, 2009
Anyone make or sell these?, looking specifically for one that has the tap that way I can screw in a meth nozzle and I need it polished to match the maf pipe thats already on the car
i dont weld and i need a screw in type so those are no better than stock other than being polished
what exactly does the hole have to do with the tank or pump?
yea you would want 9 or 3 with pretty much any setup, ill be running the AEM progressive setup
I'm not sure what you mean by siphoning but any kit I've ever used in any of my cars uses a checkvalve, no fluid gets by unless the system is spraying. I got news for ya if your not using a checkvalve I don't care if your pipe is 10ft higher than your tank or pump, your going to suck it all out of the tank just driving around. I don't use those junky solenoids either. Not everyone uses a checkvalve, again not all kits are designed properly either.
If its specifically designed why is it using a nozzle that is completely wrong for the application, theres no need for a M15 unless your running 1000hp. Pretty much any vendor outside of here whether it be AEM, Coolingmist, Snow Performance, Devils Own, etc. Pretty much any one of them would tell you a M15 is a completely wrong selection for a nozzle choice for this car.
No offense to the vendors but that kit looks like something from 2005 I made myself using home depot parts. What people on here may not realize is the level of quality thats gone into water injection kits just in the past 4 years alone. Pretty much all kits prior to 2006 or so in the industry all had the usual parts, boost switch, relay, sureflo pump, etc. They may want to get with the times a little bit and work on the look of the product, I have zero desire to have something that looks homemade in my car much less at $150 more than other kits that look better and have better options as far as progressive control.
Support isn't a good enough reason to go with a kit that isn't designed well and isn't set up properly for the application. One of the problems I've noticed with this community as a whole is that they don't seem to catch on to new products outside of what they are currently using even if they are far superior. I kind of dislike the way that everyone on here acts like this one kit is the only one that will work, when in fact it couldn't be further from the truth.
Again not trying to bash vendors, I appreciate the input but I'm just calling it like it is.
