fullahotair
- Feb 26, 2002
A friend of mine just got a 327 from his engine builder. It is a completely redone engine (bored, pistons, edlebrock Rpm top end kit). The builder broke in the engine on the stand for him, supposedly ran for about an hour or so. We saw it run, seemed to run quite well. So we get the engine home and in the car, pull the plugs to install in the headers and note that the #1 cyl. spark plug was brand new/never fired. Since the builder set the timing, i can only gather that the plug wire (new msd wires) just wasn't connected well to the plug. Now we got the engine running, and we get a lot of blow by - there is oil coming out the front and back of the intake (builder used silicone, instead of the rubber gaskets). I actually saw the oil "bubbling" out the front, and leaks out the back enought to make puddle at the back of the engine, and then pour onto the headers....It is far more than a weeping gasket.
So my question is...do you think there is damage down to cyl #1 since it didn't fire for the 1st hour of its life during break in at the builders?
Thanks!
Nate
Thanks!
Nate
