TurboWh1
- Aug 12, 2002
I have an engine I was contemplating pulling the crank in the car and just replacing the main and rod bearings. Anyone ever done this?
Here is my rational for doing so:
Some one has already pulled the rear main and #3 caps. The #3 bearing shows signs of scuffing and I don’t care for how the #4 looks. The #4 appears to look cracked and has light scuffing towards the ends of the cap where the bearing locks in. Almost from old age.... The crank looks to be in excellent shape. It does not appear to have spun a bearing but I have not heard the engine run. This engine is stock with aprox 115k miles. Engine is very clean inside so no debris to worry about. In theory, if the specs on the block are within reason of the original build then I should be able to just replace bearings?
