Here's a procedure for changing valve springs on a TB with the heads on. It could probably use some more pics, so if anyone gets ambitious and would like to add to the procedure PM me and I can forward you the Word document.
Use a compression tester with a female air chuck end attached and fill the cylinders with compressed air.. Way more simple and I'm not stuffing garbage into my cylinder.
For extra clearance on the passenger side you can unbolt the engine mount on that side and jack the engine to pick up a little room. With the correct tools it's not a big deal thoughAfter just completing this swap, I have some info to add (for those in the future who may be as dumb as, or even dumber than me.
If replacing STOCK springs, you'll notice that the stock springs have external dampeners. These must be removed in order to compress the valve springs if you're using one of the "claw-and-screw" type valve spring compressors. In order to remove them, jam a flathead screwdriver down between the spring and dampener and pry them off. It will take some persuasion, but once they begin to loosen you're almost there!!
Another tip - start with the passenger side!! Just getting the VC off is an experience. If you still have the sheet-metal shield around your AC stuff, consider removing the heater hoses to allow for removal of the VC. Once you get done with that side, the driver side will be an absolute walk in the park!! After all the trials and tribulations I faced fighting the passenger side, I could do the driver side blindfolded, with one arm tied behind my back, and balancing a basketball on my head. I used to refer to #6 as the b1tch cylinder - it now has several new variations!! You will definitely need to refill your toolbox with patience after doing these with the motor in the car.
Thanks to mtbraun for the write-up. It was a big help, as was the tip about whacking the springs with the Ford wrench before compressing the springs.
Yes, you want the valves to be closed, otherwise the air goes through your intake or out the exhaust.Do you have to turn the engine over for each cylinder with the compressed air method?
I did not have to turn the eng. over to close the valves using the compressed air method. The air entering the cylinders will push the valve up. If one is open, the other will be closed. So, there is nothing to worry about, and only one to deal with. Afterall, isn't that why your using compressed air ? To hold the valve up ?
When you pull the rocker shaft all the valves will be closed in the head.
