Okay, I took my first road trip yesterday since getting my car dialed in and confidence built up in my car. Took it on about an 2.5 *hour trip with no issues and minimum boost, in fear I might get stranded. So I get it home get all of my belongings out. I pull my phone charger out of the cigarette lighter and the whole cigarette housing came out with my phone charger. I noticed when it came out that the radio, interior lights, door dinger were not working. I then checked radio fuse, it was good. I then check "cig/clk" fuse and it had blown. I replaced it and everything started working. So this morning I went to leave, made it about an 1/8 of a mile from my house and the car died and wouldn't start. I pushed my Alky purge button and the car fired right up but was running sluggish. Thinking maybe my gas tank maybe low I filled a 6 gallon gas can and put it in. Car fired right up but still a little sluggish. I let it ideal for about 5 minutes, took off to leave again with the same results as before. Purge button on Alky system assisted it back in my garage. Where should I start looking for issues? About 2 months ago I replaces plugs, plug wires, ignition module, coil pack, fuel pump. I've had no problems at all since I've done all this and my car has been running better than ever.*
I can hear my fuel pump fire up when i turn ignition on. I've got my fuel pressure gauge on my dads car right now. But until I get it back my guesses are crank sensor or the cap, possibly coil pack/module or inline fuse under my dash.
Any guesses?
Any guesses?
