6gunn
high on gas fumes
- Sep 21, 2003
I'm trying to get the brake drum off to replace a broken wheel stud and inspect everything, but am not having any luck getting the brakes to back off by using a brake spoon to turn the adjuster. It seems that it will only tighten...and not loosen. The lower shock mount is right in the way, so I can't get a good angle to turn the adjuster the other way...plus it seems like it can only be turned one way, right? The drum is loose enough that I can tell it's not rusted to the hub, but there's probably a groove in the drum from the brakes that's holding it in place. Any suggestions?
