Flyin Brian
- Jun 18, 2011
Ok, I have a 3.5" DP with an external 46 mm wastegate and the Turbonetics variable boost control regulator P/N 10402-25 for 0 to 25 psi.
I have it plumbed up just like the Turbonetics instructions show. Boost connection on compressor housing going to a "T". "T" going to inlet of regulator and to the boost port on the wastegate. Outlet of regulator going to vacuum port on wastegate. With the regulator at full turndown I get about 13 psi boost. I am finally getting my tuneup together and am turning up the boost. 4 turns of the controller knob gets me to around 15 psi boost. More turns all the way to full on gets me no additional boost. I have had the wastegate apart one time before and it has a single large spring in it which I assume is the 13 psi one. What do I need to do to get my boost up past 15 psi? I am looking to get up to 20 psi hopefully. I would like to get a real boost controller someday but that is not in the budget right now. I am looking for an inexpensive easy fix here. Thanks.
