Flyin Brian
- Jun 18, 2011
I recently was trying to verify my timing and followed the instructions to put the car into diagnostic mode by jumping pins A and B on the ALDL connector to fix the timing at 15 degrees. The check engine light flashes when I jump the pins but the timing does not change. It just stays around 28 degrees at idle. Is the SD chip not designed to do this??
