Jim Blackwood
- Feb 25, 2007
I'm trying to decide if an automatic transmission will work for my application, which is a blown Buick 340 in an MGB, weighing 2500lbs. The requirements are significantly different than for drag racing. First, I need positive control of gear changes. Automatic shifting is fine for cruising around town but for spirited driving I need it to stay in the gear I select, and change gears when I shift, not when it feels like it, regardless of conditions. I don't want neck snapping gear changes when cruising up to the corner store, and finally I don't want the back end breaking loose if I downshift in a corner. So the first question is; Is it even possible to get that kind of performance out of a transmission such as the 200-4r?
Thanks,
Jim
Thanks,
Jim
