Cam sensor holddown.
Red87GN
What holds down the cam sensor. I bought a project car that was not finished. The cam sensor is not held down at all right now. I found a bolt and a washer behind the seat that looks like it will fit, but is there a clamp or something to hold down the sensor like on a distributor?
John:confused:
1 inch long bolt with a washer attached to it...
that is the bolt that holds down the sensor, make sure you use a 14mm 1/4 inch drive with a extension, or else you WILL cross thread that SOB
OR use a bluepoint ratchet wrench with the reversable lever
been there.. still got the grease under the fingernails
HTH:D
