Cam or not?
gnman87
Okay -- broke the crank.. I have the engine out and am wondering about upgrading the cam. It's a Jasper's engine -- now with a 20/20 turbo crank -- standard heads.. 36# injectors.. alky, 70mm KB tb and plenum, billet fp reg -- what do you think? Cam? I'm hearing good things about the 206/206 --
any help would be great..
jp
Now would be the time sure enough if you're leaning that way. I mulled over the decision somewhat as you are and decided to do it. I opted for a mild grind 205/205 Reeds. Glad I made that choice overall. The upper side of the low end and the mid range is exactly what I needed. HTH.:cool:
