L leehatten turbo rust Joined Jun 23, 2005 Sep 15, 2008 #1 I am looking for stock replacement cam lifters push rods and valve. Where can i buy stock replacement
S SouthernCal GN I come in peace....AK AK Joined Mar 18, 2004 Sep 16, 2008 #3 I have a 204/214 cam and lifters that were in an engine for about 250 miles, then I went roller.
L leehatten turbo rust Joined Jun 23, 2005 Sep 16, 2008 #4 do i need to change the from the 80 lbs valve spring to the 100lbs also do i need to change the length of the push rods
4 49-blues Active Member Joined May 30, 2001 Sep 16, 2008 #5 Sealed power has a similar slightly larged cam than stock- id go with the 204/214.
S SouthernCal GN I come in peace....AK AK Joined Mar 18, 2004 Sep 16, 2008 #6 Depends on your goals- the stock ones (new) are fine for stock/mild build applications (11s).
D dsmith4994 Member Joined May 5, 2004 Sep 16, 2008 #7 re: cam I have several used stock cams in good shape for sale if you were looking for used....Dave
L leehatten turbo rust Joined Jun 23, 2005 Sep 17, 2008 #8 well considering we dont have a track here in honolulu there is no need to go fast so stock or mild is all i need
