Having an issue with a 2004r I assembled for a friend...had it in and out of the car several times in the past couple weeks. Here's what I found last night after disassembling the valve body. At the line bias valve port in the valve body there is supposed to be a spring that goes in front of the valve. This valve body was missing the spring there. Question is how would this effect the operation of the transmission??? It was also missing the spring at the TV modulator upshift valve....Fighting a pressure issue with this trans. At full TV and about 1500rpm in park I initially get around 265lbs of line pressure. But, it quickly drops of to about 150lbs...It is dual fed with billet hard parts and I am 99.99% sure everything is right inside the transmission. I'm focusing on the pump and valve body now.
