Brand new Harland Sharp roller rockers
earlbrown
runs with scissors
I made a deal with Harland Sharp to pass on a group purchase to the Buick community for a little while. (rather than doing a normal group purchase where everybody gets on board, then they get hammered with orders at once).
I can do check, money order, or 'friends and family' on these.
Right now, the 1.55's and 1.65s are boxed up and ready to ship. $550 a set plus shipping (8# box from 30240)
can you tell us a little bit about them? more than just what is on their website?
If you’re going to run a roller cam with increased spring pressures, rockers like these are usually pretty much required to handle the extra load. The cylinder heads need to have the rocker pedestals clearanced to accept these rockers. And these rockers are adjustable where the stock system is not.
Yep. I tried to get away using upgraded stock shafts with shaft supports. Turns out the rocket tips and my SS valve tips are all beat up, chipped and pitted after less than 1000 miles. And that's with beehives not some real stiff double springs.
And they let me add a little more preload to my lifters to quiet them down.
I have gn1 Champion aluminum 8 bolt heads.
They should work.
I'll wait on price with shipping to 60073
Shipping to 60073 will be $10. So if you do Friends and Family, $560 to your door with tracking.
Stockers, look how far they are off center of the valve stem.
Hs 1.55 rockers note the offset
