I've been having a problem since I upgraded my brakes in the front and back.
I put Baer sportstrack 12" in the front and PBR 11" disks in the back.
I have blead all 4 corners and the pedal is very very firm so there appears to be no air in the system. I also have a vacuum booster upgrade with an appropriate master cylinder. I have also done the proportioning valve modification that Baer recommends for the Disk-Disk setup.
I have also verified that the brakes do work on all 4 corners.
The problem I am having is that it seems I have to press really hard on the pedal to get any braking power. Do I need to upgrade the master cylinder for the new Baer brakes? Or could the master cylinder be shot? What else could it be?
Thanks,
Don
Thanks,
Don
