B "Black Ice" Member Joined Jan 2, 2010 Jun 27, 2017 #1 If you go to a intercooled set-up on a '84/'85 GN. Can u still use the same brake system, or would u have to go to the '86/'87 set-up. Thanks
precizion818 Well-Known Member Joined Nov 29, 2007 Jun 30, 2017 #2 Yes, you can use the (assuming) HydroBoost system with the Inter-cooled set up. Will have to use the 84/85 lines and install a T fitting in the power steering return line Sent from my iPhone using Tapatalk
I Instro84 USAF retired Joined Jul 17, 2005 Jun 30, 2017 #4 yup hydroboost worked great. i also upgraded to 4 wheel ls1 disc on mine.
