I have the pan off to replace the govoner spring and was thinking about upgrading to the PTS TV .520 boost valve . Where is it and what has to be done to install ? thanks.
The bore next to were the filter pick-up tube goes into the pump. There is a snap-ring, it's under the ring, that's all you have to remove to get it out. PS. Bruce should have the spring you need also. PSS. you might consider the whole PR system?
Thanks guys , I just ordered the spring and 'pressure regulator Kit" from Bruce .from what I understand this kit installs in the same bore mentioned above . Is this correct . Thanks.
