I posted this on TurboBuicks.com since this site was down or my system was messed up and wouldn't allow me on here.
Anyways, I just bought an '87 T-type Buick yesterday and I'm having an issue with the boost. When I get in the boost, it doesn't seem as much as it shoud be and it makes a loud sound from the CAI (driver side clear as day). It's like the boost controller is dumping a ton of boost and it's bleeding out through the CAI. Also, the boost gauge is broken or not hooked up right. I've checked the IC hoses and clamps and everything seems snug tight.
Mods: I'm not to for sure on most of them but this is what I know now.
208/208 cam
p&p heads ( stock heads though)
chip ( unknown ATM what design program)
TE44 turbo
42lb injectors
Fuel regulator
Houston 3" DP.
Boost controller ( manual and unknown brand/design)
3000 stall converter ( PCT extreme 9" ?)
Also, does anyone know how to return the car to the stock boost/wastegate settings? I'm wondering if the boost controller is bad? And also does anyone know where the best place to hook a boost gauge up at?
Thanks for your help an opinions
Ray
208/208 cam
TE44 turbo
42lb injectors
Fuel regulator
Houston 3" DP.
Ray
