T TD2593 Grumpy Joined Jan 19, 2002 May 7, 2003 #1 What are some of the things you FAST tuners are doing to cut down the time it takes to build boost with an automatic and two step. I need to get the boost up faster for pro tree racing. Motor is 397 cid with twin 76's q trim. Thanks
S steve hughes Well-Known Member Joined Jul 5, 2002 May 7, 2003 #2 Retard the timing and give it some fuel for spool up. Retarding the timing creates more heat.
