Snake Killer
- Apr 20, 2005
Recently the motor in my 87 went south for the winter, and now i'm rebuilding.
I bought the car used with a "fresh" motor from a machine shop, and the previous owner said he knew nothing of the motor build, build quality, ect ect, with turns out to be ****, but after pulling the motor i've discovered its been punched out to .40 and the pistons have big cracks in them.
The cylinder walls look fine, crank needs to be turned, needs new bearings all around, pistons, rings, probably a crank depending on how bad it is, but every machine shop i've called has just told me to throw away the motor? They said if I'm trying to make any boost on this block, with it being over that much, its going to go kaboom, and I wont be happy.
So i'm asking anyone and everyones opion on the matter, is it worth putting back together, or am I doomed to find a short block and start all over?
