Tim Barnum
- Oct 15, 2001
Yes, The car is running too rich. I've checked almost everything on the car. I replaced the ECM, Mass air, stock injectors, fuel pressure reg., fuel return line. The car has 42 lbs fuel pressure with no vacuum. It also takes about 20 seconds to start after it has been setting for a while. Otherwise it will start right up when hot. It also cuts out when you take off from a stop. Any ideas? Thanks Tim
