T tomjon Member Joined Jul 11, 2002 Oct 5, 2003 #1 What would you do? At WOT, O2 is at approx 850. 1. Lower fuel pressure 2. Lean out fuel % at WOT (I do have trans +) 3. Raise boost Thanks for the help.
B Blown&Injected Active Member Joined May 31, 2001 Oct 5, 2003 #2 If no KR UP WITH THE BOOST it is the only way to fly
turbo nasty Turbo Dojo / MNTR Joined Jul 19, 2001 Oct 5, 2003 #3 With 850 @ WOT, add 1 psi at a time till you get your target ....780ish is a common area. if still no knock, keep going.
