T type,
I can try that, but in theory there should be no difference if there was 20 psi on the gate with 2psi from the spring and 18psi from co2, or 16 psi from the spring or 4 psi from co2
Also I would like to keep a lighter spring in the gate so I actually have control for the launch.
I can try this how're because I have higher poundage springs.
I'm beginning to suspect that my calve lash is set a little too tight. I noticed at low boost I was loosing around 2psi at higher rpm and at higher boost I'm loosing the same 2 psi.
All these ideas and I'm on the ther side of the world right now so I can't test anything.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
