Does it bounce even at an idle?Hi guys,
The last couple times out, I notice on my scanmaster that my battery voltage fluctuates from 11.1 to 14.8 volts bouncing around pretty rapidly. I'm assuming my alternator is going. Sound normal for a bad internal voltage regulator?
Thanks.
Rich.
Dash lights while it's dark outside?It does bounce at an idle. Dome light doesn't work but headlights do intermittently dim while driving.
Yeah my scanmaster tells me 11-12 volts at idle but at the back of the alternator and battery 14.49 or so.i think I am loosing the at the starter.or maybe ignition switch..
Scanmaster reports the value sent in the ALDL stream from the ECM register.
