Take them OFF. Myself and several others have either almost wrecked or wrecked due to teh rears locking in panic stops or wet roads, etc
I have a friend with eth big Baer brake swap on teh front of his t and the s10s on teh back and his rears still ocked..I say take em off on the street.
Thats how it for me too. 10lb+ launch.S-10 wheel cylinders, aluminum drums and all long shoes...no issues...other than holding more RPM's on the line.
I used a caliper thingie and was very close. A quick drive down the street and a hard brake showed which was alittle too tight. Backed it off a touch and was done. I do have larger than stock M/T drag radials on so that might also help with keeping the rears from locking up too.If you dont adjust them crazy tight, you'll be okay with them.
Also leaking wheel cylinders (my issue before the change).Be sure your axle seals aren't leaking. That's a more common problem with rear brakes grabbing.
