N NY87GN Member Joined Jul 3, 2013 Nov 2, 2015 #1 Just need help, not sure where this plugs into.. many thanks. Attachments 1446475199270.jpg 60.5 KB · Views: 94
S SHADOWII Well-Known Member Joined May 12, 2004 Nov 2, 2015 #2 Wow, you really did it now!!! J/Kidding. They are the hi and lo speed fan relays. do you have an aftermarket set up?
pacecarta LOGGED OUT Staff member Joined Aug 1, 2003 Nov 2, 2015 #3 the connectors are for the powermaster brake unit .. 4 pin to motor ,3pin to brake pressure switch you dont need them with hyroboost , just tuck them under the wiper motor
S SHADOWII Well-Known Member Joined May 12, 2004 Nov 2, 2015 #4 pacecarta said: the connectors are for the powermaster brake unit .. 4 pin to motor ,3pin to brake pressure switch you dont need them with hyroboost , just tuck them under the wiper motor Click to expand... Thanks for the correction, pacecarta, I just took a quick glance and ASSumed they were the plugs pulled from the relays. Didn't take notice they were straight plugs. Good rescue.
N NY87GN Member Joined Jul 3, 2013 Nov 2, 2015 #5 I really appreciate it.. this forum is so helpful. I would be totally lost without it.
