aluminum head epoxy
postal
Peoples champ runner up
I have seen that alot of stage heads have a layer of epoxy on the floors of the intake ports. Can anybody tell me what this epoxy is called? any particular brand name? and where do you get it? I need some for a project.
Thanks: Jason
Filler
To be specific:
You are looking for DEVCON ALUMINUM PUTTY (Epoxy Compound) Stock No. 10610
I have not used it on any Buick stuff but with great success on intake runners on M/Cs. With the M/Cs, I put an aluminum plate (secured with a aluminum sheet metal screw) with the putty under it as a filler. After results were positive and the only way to remove the material was with a grinder. The material is NOT
cheap...
