Alternator Questions
Wolfj359
A 6 8 U
I just replaced my alternator with an optima lifetime 120 amp alternator from oreilly's and it charges about 13.5-13.7 but when I turn on the ac it barely gets over 12 volts. It says ac delco on the back of the alternator but just doesn't perform like I think it should. Should I go with a different alternator or did I just get a dud? I know its hard to find good alternators for these cars.
Nothing wrong with that alternator. Scanmaster #s aren't from back of alternator and read low. Don't worry about it. ;)
what pulley is on that alt? Make sure it isnt larger than youre original.
13.8 at the bat would be ok *if* it would stay there. Most of the ones I've measured were 14.1-14.2 volts at ~2000. Make sure the regulator is getting full field voltage by using a wire direct from + battery post to alternator field input.
If you don't then get 14 volts at batt regulator is suspect.
